Bug679 Posted January 11, 2016 Share Posted January 11, 2016 Hey folks so i got a really fucked up noise coming from the gearbox/clutch.the noise goes when the clutch is pressed down but when the car revs it gets louder anyone any ideas what this could be? I changed the rear main seal as it was leaking and put everything back on in the correct order just it's a different gearbox this time , bought it as my last one the bearings where going and the clutch is nearly new as well ya can also hear the starter is struggling to start it to . any help is always appreciated Thanks http://vid834.photobucket.com/albums/zz265/bugmb6/iphone657890%20232.mp4 Quote Link to post Share on other sites
H_D Posted January 11, 2016 Share Posted January 11, 2016 Its will be the release bearing. its should be changed when its removed Quote Link to post Share on other sites
akyakapotter Posted January 11, 2016 Share Posted January 11, 2016 sounds like the metal plate is rubbing on the flywheel to me Quote Link to post Share on other sites
kbond Posted January 11, 2016 Share Posted January 11, 2016 As above, box back off and you will be able to see where it's catching Quote Link to post Share on other sites
Bug679 Posted January 11, 2016 Author Share Posted January 11, 2016 Right so went out to have a root around at the yolk and noticed this on the old gearbox. It's an N/A gearbox and new one is a Gt turbo box. The clutch am using is a turbo clutch 212mm What's causing this ? This is obviously the problem and why the car is hard to startT Quote Link to post Share on other sites
