Took my charade block to be decked and turned out to be warped somehow.strange for a block. This was the better of the blocks i had so now left with a block that has 15thou of it and a head with 10thou plus on it. Obviously this is now going to cause issues with timing and exhaust valve clearance. Standard headgasket is 1.25mm crushed so looking to have to run around a 2.25mm gasket or standard gasket and decompression plate. Have read mixed reviews on these and wondered if anyone has ever used one?
are you sure because i have never seen blocks ( car ) before that cant be machined on aslong as the piston does not protrude the top of block your ok timing wise
just fit a 2mm steel gasket if they are available for your 3 pot
Yeh 2mm is available, may have to try get a custom one slightly bigger. They are pretty sensitive to piston to valve clearance. Not non interference like the 4es
