Neo95 Posted January 25, 2016 Posted January 25, 2016 Im going at 300bhp I have a TMD engine an I am womdering do I really need to get the fittings welded in or would it be ok without?Thanks Neil. Quote
5e colin Posted January 25, 2016 Posted January 25, 2016 deffo need it back pressure in the block is no good it will blow the seals out etc if it was me id have minimum 3x an10 fittings pipes to get rid of the blowby Quote
epcashin Posted January 25, 2016 Posted January 25, 2016 an8 is fine for 300hp and 2 is fine on the cover Quote
Neo95 Posted January 25, 2016 Author Posted January 25, 2016 an8 is fine for 300hp and 2 is fine on the coverThis is what i have seen before never seen 3 to be honest with you Quote
RobSR Posted January 29, 2016 Posted January 29, 2016 An-10 is really the minimum you want to get the best air / oil separation, 2 are fine on our cars. Quote
Whitenoize Posted January 29, 2016 Posted January 29, 2016 2xan-10 is what I'd go for the breather on the rocker is already around the same size as an-8 so no real advantage fitting an-8 Quote
