morgan Posted January 26, 2016 Posted January 26, 2016 Putting some though in to getting and building a forged 5e.But would I use the head off the 5e or do I need to get one from a 4efte, same with the cams, can I use a 5e head but have to run the 4efte cams. Or does it not matter what so ever? So what bits do I HAVE to use from the 4efte to make it turbo.I was going to get a sump from a 4e ep95 and get it baffled as there is a possibility I will be putting this in to a 4 paw in the future.Any help would be great Thanks Quote
AdamB Posted January 26, 2016 Posted January 26, 2016 Do a search on here, I think it's Gorganl2000, has written a guide on everything you need for a 5E build. Quote
5e colin Posted January 26, 2016 Posted January 26, 2016 heads are the same cams are the same unles its a 5efHe just valvesprings are stronger on the turbo parts needed from 4efte when your forging the 5e is sump and oil pic up( or weld a bung on your sump of the 5e ) thermostat housing and oil filter housing 3ete flywheel or redrill 4efte fly Quote
gorganl2000 Posted January 28, 2016 Posted January 28, 2016 http://www.toyotagtturbo.com/forums/showthread.php?9694-Whose-done-a-5E-Conversion scroll down a few poststhere is no set formula for a 5efte, but those are the basic guidelines Quote
