turbo-fever Posted January 31, 2016 Share Posted January 31, 2016 Anyone suggest a good place for a decent alternator for ep82 ? Also running a 5e setup so can I just get a 4e alternator ? Quote Link to post Share on other sites
FMuscle Posted January 31, 2016 Share Posted January 31, 2016 Depends on your wiring, When I swapped my 5E I had to reuse the 4E alternator, the connector was different. Quote Link to post Share on other sites
turbo-fever Posted February 1, 2016 Author Share Posted February 1, 2016 Any idea on what the differences are between the 5e and 4e connector ? Quote Link to post Share on other sites
FMuscle Posted February 1, 2016 Share Posted February 1, 2016 I'll have to check if I still have the 5E tomorrow. I know I have a spare 4E easily accessible. 4E is from EP91, my 5E is from a EL44 Quote Link to post Share on other sites
Stu Posted February 1, 2016 Share Posted February 1, 2016 4e alternator will work. Plugs sometime differ but the circuit design is the same (ie charge post and three pin plug with sense/ignition switch/charge light wires) so you can just swap on the right plug if need be. Quote Link to post Share on other sites
