typh183 Posted February 1, 2016 Posted February 1, 2016 my ep82 gt turbo is misfiring pretty bad and the person i bought it from says its possibly the piston rings or the 3rd piston melted. he didn't do a compression test on the car and just thinks it could be piston rings etc, it seems to start up fine and idle fine just a major misfire all the time. Just wondering whether its worth fixing the engine thats in the car atm or just go ahead and find a replacement 4efte, haven't got a huge amount of money to spend budget is around 600 700 pounds... Quote
5e colin Posted February 1, 2016 Posted February 1, 2016 probably ringlands or chipped valve use the money to buy another 1 and invest it in this 1 so you can rebuild it piston can be replaced with the engine in the car so not to big of a job if your in the know how either way head has to come of if your lucky you might see a chipped valve instead Quote
typh183 Posted February 1, 2016 Author Posted February 1, 2016 probably ringlands or chipped valve use the money to buy another 1 and invest it in this 1 so you can rebuild it piston can be replaced with the engine in the car so not to big of a job if your in the know how either way head has to come of if your lucky you might see a chipped valve instead i would much rather rebuild the current engine, i dont mind removing the engine and doing work my self. I've worked on a few engines and have a friend who knows quite a bit about starlets who can help. Just dont wanna sink 1000 pound plus rebuilding a stock 4efte. im going to compression test it this evening and whip the head off tomorrow. Quote
H_D Posted February 1, 2016 Posted February 1, 2016 bell me after 6pm bro. I will inspect it with my borescope for you Quote
