patman Posted February 2, 2016 Posted February 2, 2016 Brought a turbosmart of jdm-ep ages ago and was gonna fit it and see what the crack is, after doing lots of research I can not find what to set the actuator to? At the moment I am on 0.8bar, so I presuming the more I close the MBC it will then go to 0.7, 0.6 and so on so when it's fully shut there's no boost, and if I open the MBC fully it will be back to 0.8bar? Anyone shred some light on this please or am I wrong with all the above.Thanks Pat Quote
karl. Posted February 2, 2016 Posted February 2, 2016 You have got mixed up. If you set your actuator to 0.8 and fully close the mbc you will get 0.8 bar of boost. If you open it slightly(assuming its a bleed valve) you will get 0.9 bar and the more you open it the more boost you will get. Your best just using the adjustable actuator over the mbc Quote
Ollieh17 Posted February 2, 2016 Posted February 2, 2016 first mistake was buying a turbosmart of jdm ep. Id send contact turbosmart and confirm its real before you risk running it Quote
patman Posted February 2, 2016 Author Posted February 2, 2016 Thanks for the tips lads, i will just leave it as it is then, I was gonna put it on, just because I had it for ages but will just leave it off now Thankyou Quote
