Item For Sale: motec m4 ecu + sensors
Item Condition & Description: good condition comes with the following
* motec m4 ecu
* D9 Communication Lead
* GM 3 Bar Map Sensor
* 10 position Switch (Allows in car boost control and trimming of maps etc.)
* Throttle Position Switch (Starlet throttle position switches are not linear, when fitting a motec ecu this linear throttle position switch is required)
* 36 Pin male Connector
*standard boost solnoid (fensport use these on all there cars)
This ecu was on a ex sprint series ep82 and was mapped by fensport on switchable maps and with road fuel and race fuel.
Motec information
The M4 is one of MoTeCs earlier generation engine management systems. Highly capable and still very popular, the M4 represents excellent value for sequentially injected four cylinder and turbocharged applications.
Engine Tuning Features
The DOS-based tuning software is efficient and easy to use.
Individual cylinder tuning of both fuel delivery and ignition timing
Suits modern engines, including those with coil per cylinder ignition
3D fuel and ignition tables for engine mapping
Table axis selectable from a range of channels
Fully configurable axis points on fuel and ignition tables
Full sequential crank and cam trigger system to suit almost all OEM sensors
Boost Control
Fully configurable sensor inputs including custom calibrations
Free access to wideband Lambda and data logging for initial tuning. Available for the first 6 hours engine running time
Several upgrades are available to increase the functionality of the M4 including traction and launch control, anti-lag and data logging, to name just a few.
Price: £1200 collected
57395A06-0AF0-4C8A-8CA3-099DD8E28EF9_zps
Payment & Shipping Details: As above if delivered at owneres risk but will be sent recorded and signed for
  • 1 month later...
