maloo Posted February 12, 2016 Posted February 12, 2016 Hi i just replaced my clutch kit since it was slipping and i thought of making a light weight flywheel.I fitted everything and when i went to start the engine wasn't cranking good and i heard a noise metal to metal and the engine couldn't startI removed the gearbox and found that the starter wheel gear was stucking with the flywheel ring. (when it was going out it was stucking and remains stuck with the flywheel ring)Anyone of you might know what can be the problem?? Thanks Quote
5e colin Posted February 12, 2016 Posted February 12, 2016 is your fly for a 4efte ??? could be that you need to space out your startermoter can you see marks on the backside of the starter theeth on the fly itselve ?? Quote
daniel_g Posted February 12, 2016 Posted February 12, 2016 How did you 'make' youre lightweight flywheel? Quote
maloo Posted February 13, 2016 Author Posted February 13, 2016 @ 5e colin yes it is a 4efte fly wheel i checked they have the same tooth same height same width. And yes im seeing marks on the flywheel (starter side) @daniel_g i just bought al lightweight flywheel its brand new Quote
5e colin Posted February 13, 2016 Posted February 13, 2016 try spacing out the starter by fitting washers between starter and box Quote
maloo Posted February 14, 2016 Author Posted February 14, 2016 to tell you the truth thats what i did... but i want to leave it like that, i thought maybe something else is wrong...But thats the only solution i think :/Thanks for your help Quote
