Hi i just replaced my clutch kit since it was slipping and i thought of making a light weight flywheel.
I fitted everything and when i went to start the engine wasn't cranking good and i heard a noise metal to metal and the engine couldn't start
I removed the gearbox and found that the starter wheel gear was stucking with the flywheel ring. (when it was going out it was stucking and remains stuck with the flywheel ring)
Anyone of you might know what can be the problem??
Thanks
@ 5e colin yes it is a 4efte fly wheel i checked they have the same tooth same height same width. And yes im seeing marks on the flywheel (starter side)
@daniel_g i just bought al lightweight flywheel its brand new
