neilsmith Posted February 13, 2016 Posted February 13, 2016 My engine has developed a rattling sound that only occurs when at full running temperature and at around 2k rpm with no load on the engine, I don't think it's the bottom end but hopefully one of you guys can helpJust to clarify I haven't driven the car any more than a mile like this I heard it on my way home on Sunday nightAny help appreciated guys!https://youtu.be/u90ld5N6Wm4 Quote
neilsmith Posted February 13, 2016 Author Posted February 13, 2016 Just to add there is a crack in the exhaust manifold which is blowing only very slightly but I don't think that has anything to do with the rattling soundNeil Quote
aleximport25 Posted February 13, 2016 Posted February 13, 2016 When I got my v the mani split in two and was only held together by the bolts. I had a very similar noise to yours but I noticed it more cold as when it got hot it expanded and closed the cracks Quote
neilsmith Posted February 14, 2016 Author Posted February 14, 2016 UPDATE;Measured all valve clearances and results are Intake;0.210.220.220.310.210.230.180.20Exhaust0.350.390.400.370.380.370.360.36It appears that all exhaust shims are out of the 0.3 +-0.03 tolerance And one of the intake shims are out of the 0.2 +-0.03 toleranceI'm still not convinced that this is causing the noise Neil Quote
neilsmith Posted February 14, 2016 Author Posted February 14, 2016 Removed sump and found this on piston 4 Quote
lukEp Posted February 14, 2016 Posted February 14, 2016 Your lucky. It doesn't look like it's span the shell. 4 is furthest from the oil pump so I'd be changing that as well. Have the crank measured you might get away with it. Change all bearing mains thrusts and big ends as they will all have encounter some sort of wear from loss of oil pressure. Quote
neilsmith Posted February 14, 2016 Author Posted February 14, 2016 Luke you right I think I may be very lucky lol The oil pump hasn't done any more than 2k miles but there has definitely been a loss of oil pressure somewhere along the line as the oil light was flickering a bit on tick over so I will change that anyway but do you think there could be anything else that would cause a loss of oil pressure?Neil Quote
