'4AGTE' Posted February 24, 2016 Posted February 24, 2016 (edited) Just went to put my wilwood brakes onto my ep70 but have found a issue where once you put the wheel on, the balljoint locks up against the rotor. I'm running the aftermarket balljoint not a genuine one, has anyone got a photo showing the difference the aftermarket one has compared to the genuine one. I'm running ep82 hubs / ball joints etc Edited February 24, 2016 by '4AGTE' Quote
'4AGTE' Posted February 24, 2016 Author Posted February 24, 2016 Here's a couple of photos to show what's happening. Quote
turbo Grant Posted February 24, 2016 Posted February 24, 2016 What wilwood kit you nunning? Looks the the offset on the discs/ brackets is a bit out. I'v not had this problem with the 3G kits on several cars Quote
'4AGTE' Posted February 24, 2016 Author Posted February 24, 2016 What wilwood kit you nunning? Looks the the offset on the discs/ brackets is a bit out. I'v not had this problem with the 3G kits on several carsIt's just a put together kit. Was run on a ep91 for one a couple of track days.290mm rotors with a 4 pot caliper. He never had any issue with it on his ep91 which is what's confusing me Quote
jamesglanza Posted February 24, 2016 Posted February 24, 2016 I had a similar problem a while back and ended up shaving down the front casting of the ball joint, as there really think. Then bought new genuine Toyota ball joints and found they where much smaller than ones bought from local motor factors. There not that expensive from Toyota tbh might help you out. Quote
'4AGTE' Posted February 24, 2016 Author Posted February 24, 2016 I had a similar problem a while back and ended up shaving down the front casting of the ball joint, as there really think. Then bought new genuine Toyota ball joints and found they where much smaller than ones bought from local motor factors. There not that expensive from Toyota tbh might help you out. How much extra room did the genuine ones give you compared to the other ones? Quote
