TO82 Posted March 1, 2016 Posted March 1, 2016 Hi does anyone know if the U brackets that hold the trd to the car are the same as the stock ones?I know the internal diameter of the bushes is bigger, unsure about the external domensions? I have the bushes but have lost the brakets.Also the 90 degree drop links found on some GT/glanza's from the factory and in use with the trd ARB, where's the best place to get these? Are they the same as any other Toyota etc?Any info greatly appreciated! Quote
TO82 Posted March 2, 2016 Author Posted March 2, 2016 Anyone know the dimensions of the stock brackets? Quote
karl. Posted March 2, 2016 Posted March 2, 2016 I have a TRD front arb in the garage. I can check the size of them for you if you want. Quote
adzy Posted March 2, 2016 Posted March 2, 2016 I fitted a trd front arb to mine, used the standard u brackets no probs! Don't know the exact dimensions tho.I also bought standard drop links from camskill, couldn't find them anywhere else at the time Quote
decdd19 Posted March 2, 2016 Posted March 2, 2016 I used standard brackets with the 24mm polybush off id workz and got a set of Mr2 droplinks ,, cheaper then glanza 1s an easier found Quote
Uzzy@ID-Workz Posted March 3, 2016 Posted March 3, 2016 We have Glanza drop links in stock:http://id-workz.co.uk/toyota/starlet/starlet-glanza-ep91/suspension-steering/Glanza-ARB-Drop-Links-Anti-Roll-BarUzzy Quote
TO82 Posted March 3, 2016 Author Posted March 3, 2016 Nice one lads cheers for the help, are those mr2 drop links for the new shape (mr-s)? Quote
