Duduglanza Posted March 5, 2016 Posted March 5, 2016 Where do you weld the bung on a side exit. on a normal exhaust its 35" away from turbo.. but side exit it means nearly at the end. does it read accurate? Quote
5e colin Posted April 27, 2016 Posted April 27, 2016 put it just before the silencer i run mine in the oem location its only 24 for optimum but it will read just fine closer to the turbo to sensor might need changing more often thats al Quote
