Legend009 Posted March 8, 2016 Posted March 8, 2016 Hy guys. I have an ep82 GI and i want to install a tachometer for my rev count. Any tutorial on how i can go about it please?? Quote
5e colin Posted March 8, 2016 Posted March 8, 2016 tap into your coil for signal as im not sure if there is a ecu pinout for the gi you could open the ecu and read the pins that way Quote
Legend009 Posted March 9, 2016 Author Posted March 9, 2016 Cool. Il check it out this weekend. Any place i can get pic tutorials Quote
EP70-PT Posted March 22, 2016 Posted March 22, 2016 Basically, you have 3 wires on a tacho, ground, rpm signal and 12v (for the lights if it had any and maybe one more wire for the dimmer), you can get the RPM signal from the ignition coil as said by 5e colin, you can also get it from the RPM signal of your ecu the cool light be easier though, will get a diagram for you Quote
EP70-PT Posted March 22, 2016 Posted March 22, 2016 Here you go, a quick trip to Google and it's done.. Quote
Legend009 Posted March 22, 2016 Author Posted March 22, 2016 Thanks pal. Will try it and give a feedback. Quote
NewbieLewby Posted March 26, 2016 Posted March 26, 2016 behind your clocks there should be a wire with a thick black or brown coating on it, on the right of the middle plug. this is a rev signal. then just earth and power. gotta install mine on my new car Quote
Ep82gi Posted March 26, 2016 Posted March 26, 2016 I've got a gi and mines got a Rev counter. How comes yours dosnt ?? Quote
5e colin Posted March 26, 2016 Posted March 26, 2016 I've got a gi and mines got a Rev counter. How comes yours dosnt ?? he has a micra you got the proper ep82 na ha ha ha Quote
starletezy Posted March 27, 2016 Posted March 27, 2016 Tap into your negtive wire on your coil thats how its usually done Quote
Ep82gi Posted March 28, 2016 Posted March 28, 2016   he has a micra you got the proper ep82 na ha ha ha Ahh thanks Colin I'm really interested to find out how many of the Gi's are around to be honest don't here much about them Quote
Legend009 Posted June 6, 2016 Author Posted June 6, 2016 Mine is a soleil l. I finally got some time off and i managed to install the tach. Looks cool. Will get some pics up soon. Next step now is to turbo. Quote
