Tachometer installation
Basically, you have 3 wires on a tacho, ground, rpm signal and 12v (for the lights if it had any and maybe one more wire for the dimmer), you can get the RPM signal from the ignition coil as said by 5e colin, you can also get it from the RPM signal of your ecu the cool light be easier though, will get a diagram for you :)
  On 3/26/2016 at 11:07 PM, 5e colin said:
he has a micra you got the proper ep82 na ha ha ha
Ahh thanks Colin I'm really interested to find out how many of the Gi's are around to be honest don't here much about them
  • 2 months later...
