Legend009
    62
1 Follower
    Kenya
2327 profile views
Legend009's Achievements
  1. Hy guys. Is there anyone who has a pdf on an ep82 4efe fusebox pinout on the engine side?
  2. Hellow guys. So I have a ct12b turbo from a 1kz engine. Thinking of fixing it on the starlet by using the ct9 exhaust housing. Any ideas if it’s possible as am told a Diesel engine turbo is different from a petrol engine. Is there any one who has tried this setup?
  3. Hy guys. So I just swapped in a 4efte and the only loom changed was engine side. The cabin loom looks like it wasn’t touched. Changed the pinout to how a 4efte cabin loom should be.My air conditioning system isn’t working however the ac computer comes on but the compressor isn’t coming on. Any ideas on what I should check next?
  4. Thanks guys. I think I’ll stick to the celica one.
  5. I am not sure if this has been posted before, however I’m getting a set of twin pot calipers together with the hub. Does the hub bolt on to the Ep82 or are there some mods needed?
  6. Legend009
    Ep82 ecu
    I’ll check on that. I got a 4efte glanza V engine but without the harness and ecu. I got an ep82 harness and the glanza ecu, however a friend of mine has the EP82 ecu and is willing to give it to me since he is using an aftermarket one. Are there any bypasses to be done if am going with this setup?
  7. Legend009
    Ep82 ecu
    Can an ep82 ecu work with an ep91 4efte engine?
  8. Hehehe you from kenya too Bro? Am from mombasa. Our temperatures range between 26 - 30 degrees with a feel of upto 32 degrees. Let me check on the thread. Mine is an ep82.
  9. 2.5" core
  10. Is it possible to install a front mount and not remove the air conditioning system? Realy cant survive the heat at times in my location.
  11. So i have a friend of mine who went ahead and messed up his air fuel ratio on his carb 4ef. Any ideas on how to set it back to normal?
  12. There is one NA just rotting away in town. Il try follow it up. Would be a killer and converting it to RWD. So best is to just upgrade the 4efte
  13. So i got a realy good offer on a 3sgte 3rd gen engine. Two injectors not firing and needs a new turbo. Is it possible to fit it in the EP82 and if yes what is needed and what mods are to be done?
  14. How did it go?? The rear wheel ep82 are so rare.
  15. Has anyone tried doing a rear wheel conversion to an ep82 4 door??
