Matty1997
    63
About Matty1997
  • Birthday 04/17/1997
    Doncaster
1949 profile views
Matty1997's Achievements
  1. Up to now I have plenty of plans for the winter, new alloys, drilled and grooved disks, refurb the coil overs, live sports wings, jam side skirts and also a fresh coat of paint as I’m not really happy with the plasti dip that’s currently on her! All this is to come though! And also getting the mapping sorted when the new fuel pump is fitted! Sorry to everyone that’s been following the thread and me being quiet recently, I’ve had lots going off in my personal life and haven’t really had the time to be updating, however I’m not back and will be posting plenty of cool updates through the winter!
  2. With the engine built back up and in the car ready, it would be rude not to get stand alone management to run now that everything is slowly starting to come together! I decided to run ME221 .ecu maooednst RDT, however I’ve been restricted at the minute as my current fuel pump isn’t up to the job, not to worry as I’ve got a new pump though and it’s ready to fit to unlock the cars full potential when the time comes! The walbro 225 was my choice of pump!
  3. Now that’s I’ve got the internals to run bigger power I needed to get some injectors that would be up to the trick with fuelinf! So I decided to get some 440cc supra injectors which was freshly reconed
  4. I decided to go for the common choice of wossnier pistons and PEC Conrods after hearing so much positive things about them. I just couldn’t refuse!
  5. So I’ve been quiet for a while... turns out my car has been through some serious surgery this year... starting with the head gasket shitting itself and the head warping not only to fine my block cracked too. After sourcing a new block and sending the head off to the machine shop it came back awsome! I also surfed a new block and has that sent off too! The machine work was absolutely amazing!
  6. Matty1997
    Low idle!!
    It’s a new issue mate, thanks for the advice I’ll see if it helps
  7. Matty1997
    Low idle!!
    My engine seems to be idling very low even 250rpm where it seems hesitant to cut out... the oil light blips when the revs get too low, any advice?
  8. Sorted it mate it ended up being the other wire aha! Only issue I’m having is my after market taco reads around 300rpm higher than my actual taco on the clocks lol
  9. Aha thank you! I’ve tried one of them and no luck so it’s gotta be the other lol! Cheers mates
  10. Hello, really need help, I’ve fed all the wiring for my taco power and earth etc, I’m now looking for a source of signal on my ep91 glanza, can anybody help me please and tell me where I can get the signal feed so I’m able to use my aftermarket taco thank you!
  11. What colour wire was it Toby? As I’m planning on doing the same thing to mine today and I don’t want to run in to any issues lol, rather know what wires I’m going to be chopping in too! thanks
  12. New wheel and shifter now in
  13. She’s on!!
  14. Okay guys I know this one might be really simple for you but what is the size for the 2 bolts that hold down the middle section of your rear strut brace to the bot floor, can’t seem to get the right thread type anywhere... thabks in advance!
  15. Even got some nice photos of her!
