paddy
    336
    Essex
4023 profile views
paddy's Achievements
Member (4/8)
  1. Right I have just had the engine of my glanza out, had head skimmed, new gearbox, new clutch and new cambelt. While the engine was out I replaced the rear main oil seal, it wasn’t leaking but replaced it to be on the safe side. Put the car all back together, runs really well but it has a bad oil leak from crank seal area. So off came the gearbox again, replaced the seal again, re sealed the seal housing, still leaking, re sealed the sump, still leaking, resealed the sump again, still leaking. I’ve spent over 20 hours fixing up car all for this to happen! The thing is the car wasn’t leaking before. Has anyone got any suggestions on what to do next? The sump was spotless when it was re sealed and I put a little silicon grease on the crank seal for when it was first started. Can anyone help? The cars to the point of getting broken for spares and I really don’t wanna do it
  2. Update - both front bulbs are fine, they’ve not blown, they just do not light up. When the car tries to light them up it cuts the car out. Rear indicators work fine. I tried different bulbs in the front - same problem. Has anyone got any other suggestions? A bit stuck with this one, mot is due next week. I’ve check all earths under the bonnet, nothing is loose
  3. Just had a look, both front bulbs are blown, I’ll get them changed ASAP, is there a relay for the indicators? When the car cut out this morning form the indicators it flooded the engine, was running on 1 maybe 2 cylinders which a huge cloud of white smoke out the back which was un burned fuel
  4. My Glanza died this morning, was going along just fine, went to put my indicatiors on, every time they flashed it cut the engine out, also got a massive smell of fuel from inside the car, anyone have any idea what’s causing it?
  5. These Still for sale?
  6. Still for sale?
  7. Anyone know if it’s possible to get a bearing kit for a OEM LSD gearbox, I can find one for the standard box but not the LSD one. Getting a grumbling noise from the box when it’s cold between 30-50mph
  8. Looking for a silver duck spoiler for glanza, silver rear lip and trd front anti roll bar, anyone got any of these?
  9. I’ve got a couple of glanza ecu’s message me if your interested
  10. Wanted drivers seat belt for a glanza must be good condition, needed for mot as my current one has a rip in it
  11. paddy
    Blank glanza keys
    Been 6 different places now seems very difficult to get a key cut for a starlet these days, anyone got any blank keys?
  12. In need of a glanza ep91 inlet manifold, bare manifold no tps needed cheap as possible message me
  13. Wanted blitz ecu for ep91 glanza, May concider mines what u got?
  14. paddy
    Tein Springs
    Only need 1 front but a pair or set would be alright, tein s tech springs
  15. As above in need of a new clutch for my td04 glanza, prefer a non paddle uprated clutch but what u got
