Sign in to follow this
Patches
Anyone used one of these wheel bearing tools?
I've got a rotational noise coming from my disc hitting my caliper bracket after a wheel bearing change.
I've got a spare hub to swap in so I'm going to try that next but think I'll need one of these tools to swap it.
https://www.ebay.co.uk/itm/Heavy-Duty-Front-Wheel-Hub-Drive-Bearing-Removal-Tool-Set-Kit-FREE-DELIVERY/261319029295?hash=item3cd7d3f22f:g:4lkAAOSwn45Z3I5p
anyone used one of these on their starlet?
Share this post
3 minutes ago, Calum122 said:
Don't need that tool to swap the hub over? Just a soft face mallet to tap the driveshaft out of the hub.
ah right, was thinking i might need it to press the hub in? Heard that the bearings can split otherwise, could be wrong
Share this post
Not  that I'm aware of on these cars. It's been a few years since I did both of mine on my car, but for an amateur mechanic it was very straight forward with basic tools.
Share this post
Cool man I'll give that a go first then.
Hopefully this resolves the issue
Share this post
Also make sure you don't accidentally pull the shaft out of the box the smell of used bag oil is mank !
That tool, it took a 25 ton press to change my front bearings, d/s had around 17 T on it for about 15 mins before it popped, p/s was around the same :)
Share this post
Create an account
Register a new account
Sign in
Sign In Now
