Sign in to follow this
mccartney11
Engine trouble
Swapped out gearbox in my starlet and now engine is running lumpy / hunting on start up , as if it’s off a cylinder
 thought earth was issue ran clean earths to head and inlet and still the same, lambda cable was broken so soldered and heatshrinked it and issue still there? Anyone ever have this issue?
Share this post
1 minute ago, akyakapotter said:
Un pluged the lambda to see if it stops ?
yeah tried it made no difference though
Share this post
what about the earth on the gearbox?
sounds like a vacuum leak
Edited by maerijn
Share this post
Cleaned earth strap and mount , gonna check all lines and wiring the weekend, annoying when a simple gearbox change causes this hassle:(
Share this post
Probably a dumb question but did you check all of the plug leads?
When I refitted my gearbox I was leaning over on the engine to fit the selector cables and had dislodged a plug lead into the dizzy cap which wasn't overly apparent until I stated the car and had a similar running issue.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
