JDMginge
    164
    Bracknell
3472 profile views
JDMginge's Achievements
  1. Still for sale ? Pm’d cheers
  2. My mate took the front end and I took all the bits off it to put on my new one so by the end it was just the empty shell not rolling or running Phil And ah makes sense morgey i forgot to renew it cheers And yea love the bumper always wanted one and I found it cheap and got it painted for less then most go for on any of the pages I did find them.
  3. Cheers bud and it got sent to heaven unfortunately the shell was poor and the engine was worse then I thought, under inspection the cams had chunks taken out of them and wouldn't run right
  4. It will only let me qoute it And yea I want to put the throttle bodies back on and get a mappable ecu to possible head work higher comp maybe or just go the easy way and boost lol but I'd like to stick with throttle bodies
  5. And I've forgotten how to change the project thread name ?
  6. So I've not really been very active on here and I've got a bit of an update So I bought a new sr with a much cleaner shell and I swapped everything over from my old one. Rear axle, poly bushes arms and anti lift kit, brakes and lines, panard bar, coilovers, exhaust, corolla inlet, strut braces, rocker cover, radiator, interior and whatever else aha Since owning this one I haven't fitted the throttle bodies yet but the idea hasn't gone out the window I'm thinking of getting proper management for them then getting them back on. Also since owning it I've fitted a trd front anti roll bar and white line rear anti roll bar, some crystal headlamps and amber corners, a optional arm rest and a remix front bumper I do have more pictures but for some reason photobucket won't let me upload them And I'm sure there's more done but this is all off the top of my head.
  7. JDMginge
    98 spec fogs
    Bump !
  8. JDMginge
    98 spec fogs
    As title says I'm looking for some good condition fogs with or without yellow tint as long as there in good condition with clips ready to go Cheers
  9. Sticking and won't wind back, doesn't really do anything
  10. Need a drivers rear calliper mines seized
  11. My mates gt had his reverse light on drivers side wired to the rear fog light switch for some reason could this be the same
  12. I had an issue with my key on my sr, there immobilisers cut ignition not fuel there is a box behind the glove box and a amplifier on the ignition barrel and a plug on the ring around the barrel make sure there all good to
