tr1cky
    85
    wales
tr1cky's Achievements
  1. could be a good project for someone tha van, think of the engines u could get in the back of tha, be an animal.
  2. anyone?
  3. was it worth doin, did it make much difference? I've seen the kits so u can do it yurself but id probably mess it up as I've heard its gotta be done properly or it will lose power.
  4. my car seems to be burnin oil, im hopin its the valve seals and not the piston rings. im gonna take the head off my old 4efe and change the valve seals in that 1 then put it on my 5e so its just a straight swap to save messin about. can anyone confirm that the heads are exactly the same? also is there anything else i can do to the head while its off to improve performance? someone said about a port & polish, anyone know how much it would cost? would it make any difference if i had the head skimmed down to max it would go? if it is the rings worn (fingers crossed it aint), they would have to be changed but would i get more compression from the 4efe pistons? any help appreciated tricky
  5. cant believe sum 1 done this, if sumone got a problem wiv me id rather em take it out on me than my car tha n/a was mint, 1 of the best lookin n/a's I've seen hope u catch the bastards and dont have too much trouble sortin it out
  6. anyone know wha these are like? wha sort of gains il get if any? is it worth buying? http://cgi.ebay.co.uk/92-95-Toyota-PASEO-1...ksid=p1638.m122
  7. 1's a nissan sunny an 1's a nissan micra
  8. ye this 1 looks different to the tiny turbo kit someone posted up, i contacted the guy about this 1 but there discontinued anyway
  9. click the link, dunno if its been posted up before but I've never seen anything like it http://www.castlehillexhaust.com.au/turbo-kits.php
  10. cheers guys, ye its a starlet sr wiv the 5e conversion. was an old man tha hit me, dunno how he didnt see me if im goin across the front of him to turn right but he managed, no one was hurt tho. i was speakin to sum 1 from an accident repair centre, he deals wiv things like this every day an he said it wouldnt matter if i had 4 bald tyres an no insurance they'd still have to pay out because he admitted it was his fault. so i just left it how it was and took it to nationwide for an estimate an the guy said its a write off so just gotta wait for the insurance company to get back to me, i might just buy it back off them an get it fixed because i dont think it would cost much to repair, plus be sad to see the beast go.
  11. i was turning right into a side road the other day when someone waitin on the junction decided to pull out an went straight into the side of me spinnin me in the opposite direction. the back quarter panel is smashed in and looks like the back axle is bent as the wheel looks like its towing in a bit, so will need a new o/s/r quarter panel and a new axle, also there a line goin right across the middle of my alloy and right through the speedline writing quite deep aswell so will prob need a new wheel. the guy has rang his insurance and admitted full responsibility so i had a phone call today to take my car down nationwide repair centre 2moro to check the damage. now the problem is its lowered 40mm, has a different steering wheel, a k&n air filter, different exhaust, tinted windows and tinted rear lights. i need to know if i will need to put it back to standard before i take it there, or wont it matter as im claiming off his insurance? im hoping they dont write it off but I've been told by a few people that they might, dont look like it will cost much to repair but has any 1 else been in the same sort of situation an know if they'll repair it? its a 98 sr wiv 72k on the clock cheers rich
  12. get a voltmeter an find em, cant be hard *ignition on, ignition start and ignition acc will be behind the ignition barrel *central locking wires where the wires go into by the drivers footwell from the door *indicators from the hazard switch *door trigger input is the switch where the door shuts or use interior light wiring *rpm will be behind the clocks *ignition 2 u probably havnt got *and alternator will be live from the alternator hope this helps
  13. agree wiv paul, had exactly the same problem with the huge bit in the middle of the drivers side where the blade just completely went past the water. id never buy em again. must be just not made for starlets if enzo likes em on his civic
  14. so does it do it while yur drivin or just wen its left tickin over?
  15. ye tha was in 2005, low miles didnt last long tho was on 58k wen i changed the engine
