Adeeb1395
    218
About Adeeb1395
  • Birthday 09/02/1991
    Bangladesh
  • Yahoo
    Adeebchowdhury@yahoo.com
3061 profile views
Adeeb1395's Achievements
Member (4/8)
  1. Can anyone tell me the name of the black plastic tank beside the fuel filter and how to connect it? It looks to be a part of the fuel system and may be works as a fuel tank's blow by gas collector or something not sure. Pls let me knw asap. Thanks in advance
  2. can anyone provide me the diagram for wiring the pwr ect manu switch for the 4age auto tranny and ecu??? urgent help needed pls!!! THANKS IN ADVANCE
  3. Anyone?
  4. i hv a 4efte harness which is completely destroyed by a mouse!!! so the wires are damaged and some connectors/jack are missing. what sensors does 4efte has extra than a 4efe?? air temp, knock, boost solenoid and different connector of distributor igniter and coil. anything else??
  5. need a set of all good 4efte engine wiring but cant locate one here around my place. but heres plenty of 4efe harness. how to use the 4efe harness on 4efte??? what are the differences?? i am assuming need to rewire the ecu pinouts....... any help guys??
  6. I have a 4efte whole engine and a 5e block pistons and con rod. I want to build a 5efe utilizing the 4efte. I knw the block and con rod height is different. And pistons r too. Is it possible to just install the 5e block con rod and pistons? Or i wud face any prob? Can i use the 4efte crank with the 5e block rod and pistons? Tia.
  7. Is this the proper way to convert our distributor to coil pack ignition system using honda d17 coils from 2003-04 civic?? i doubt it as its so easy to do!!!
  8. yeah was thinking about doing that. as there are no threads here or hint on web. by the way thanks for the help
  9. Going to use the full ignition system distributor, ignitor, coil and HT leads
  10. Its 5e that i m converting to 4efte distributor. Doing this convertion as the old distributor dont have both the cam and crank pickups like 4eftes. And i need those pickups to wire the aem fic6 and get it started. The car dont start with aem without this.
  11. i hv checked the connections with multi-meter. the igniter receives BLUE & YELLOW wire from the 4 pin connector and BLACK wire from the 2 pin connector the coil receives BLACKbrown wire form the 2 pin connector to the coil's + point the rest wire which is RED & White from the 4 pin connector goes to some kind of sensor.
  12. can you pls tell me or mark this pics. wud be very grateful!!!
  13. Need the internal coil distributor wiring (4 plug wires and 4+2 wire connector type) Going to external 4efte coil dizzy and ignitor setup!
  14. Some one told me there is a water line in 4efte head which needs to be blocked to install it on 5e? May be i read it on 5efte thread by tgtt
  15. My ep82 engine is 5efe. It creates high engine bay temp. But the engine temo is fully fine. Problem is my car revs 1500-1200 when cood start. When it comes to warm state the rev is fine. But if i sit idle for about 10-20 mins keeping the car on the rev falls to 500-700. If the ac is on it falls more quickly. When i open the hood i can feel the heat strongly. Cant even touch the inlet mani. What can b the problem? I have raised my bonnet Made vents on front bumper bigger Installed gt hood with turbo vent Bypassed coolant line on throttle body Installed ae100 double core full size radiator Next getting Heat wraping exhaust and inlet manifolds Flushing radiator and change coolants radiator cooling pannels Icv cleaning Any idea what shud i do else to reduce this?
