Tercel-R
    40
    Canada
Tercel-R's Achievements
  1. There are holes in the pulley that are meant for a Toyota special service tool...you can righ something up as shown: http://www.toyotanation.com/forum/103-3rd-4th-generation-1992-1996-1997-2001/208863-crankshaft-pulley-holding-tool.html
  2. Maybe you need skinnier friends
  3. Do you have an anti-lift kit and a larger front sway bar? The ALK will move the lower arms closer to the sway bar and knock on hard cornering.
  4. Are the two drop links vertical, or is one on an angle?
  5. I wanted to try tightening the top nut on my Meister's, but the top adjuster knob didn't want to come off. It was kind of spring loaded and would snap back down if I tried pulling it off. Didn't want to pull with too much force though, maybe I was just being a wimp. Is there a trick to removing it? I don't think it's the same as the D2's
  6. bump
  7. Check that the dust shield isn't bent and touching the disk. Doesn't take much contact to make a racket
  8. When I got my car tracked with meister's, I don't think they touched the lower bolts and just adjusted the camber on the top mounts. I only have -0.5° camber, but it feels kind of squirrely during cornering. After reading about scrub radius, I'm pretty sure that's the problem. One top mount has max negative camber, but the other side is only at the 1/2 negative camber mark. The tracking report said equal amounts of camber on both sides though. Something to keep in mind when getting the tracking done.
  9. Just replace the whole shaft. If you're taking it to a shop to have the work done, by the time you pay for all the parts, new boots, labour, etc you'd probably be spending that much anyways.
  10. Well that's a dirty 22mm Whiteline FARB if you can see it. Here's a picture of the car with the lowering springs. The 4pt bar would clip road kill. Any half-dead squirrels were fully dead after meeting the Ultra racing bar.
  11. I don't have measurements, but it was quite low to the ground. I took it off because it was scraping horribly. My NA exhaust was also very close to it and would hit occasionally which would drive me nuts.
  12. You probably want to do both sides....they both covered the same mileage, so the other side will probably fail soon.
  13. Replacement parts for drums are also way cheaper...
  14. Honestly, coilovers are your best bet. The limited suspension movement really stops the car from transferring the weight to the rear. A poly rear engine mount also helps.
