andyevo
    32
    Auckland, NZ
andyevo's Achievements
  1. Good write up Stu, hopefully this helps with other people running into the same problems. Just a note, the turbo is a 3rd gen Speedvision. I've read that the earlier ones suffered from seals shitting themselves. Hopefully this issue has been rectified on the 3rd generation.
  2. Yeah there probably is a bit of spilt petrol in there. I glued it down using Sikalastomer 710. Once it goes off it is very similar to the original glue. It remains soft and sticky. We use it when fitting stainless steel deck fittings on yachts.
  3. All good, I thought it was spelling😃
  4. It should leak fumes? I wouldn't think it should leak fumes into the cabin.
  5. Thanks guys. The original stuff still does stick but it's not the best seal. I'm getting petrol fumes in the cabin. I'm going to try to use sikalastimer. Mine is a 1997, and it has a clip on the cover to hold the plug.
  6. Hi guys, I've just replaced my fuel pump in my glanza and in wanting to re-glue the fuel pump cover down again. The factory glue is soft and sticky and I'm after the same stuff to replace it with. I don't want to glue it down with a product that will make it to difficult to remove later. Cheers.
  7. Your car looks so good Stu! I only just noticed the black bars going forward of your front struts. Did you make them, and where do they attach at the front?
  8. Wow it's been along time since I updated this. A new baby and house renovations has put my project on the backburner. I still managed to get a few things done and I finally have a computer that works, so update time... I got a Renault Safrane front splitter... Fitted new brakes... My gear boot was looking a little worse for wear... ...so I got one of the guys at work to make me up a new leather one... I did a bit of cleaning I fitted an HDi intercooler kit and HKS bov... The engine bay needs attention... I changed the turbo bonnet... ...to an s bonnet.
  9. Your build is next level! Awesome work.
  10. Nice build, quality images.
  11. Looking good Stu. I wondered about those brake lines, I've seen them on Trade Me. Who are you using for your cert? I was going to use N Fraser.
  12. Wheel is on... HKB 30mm bosskit fitted... The seats and steering wheel are nicely tied together now. I'm planning on doing the door cards and gear shift boot later on, as well as new carpet.
  13. Thanks for the comments guys A late Christmas pressie for myself arrived today... ...a genuine Nardi Deep Corn 330mm steering wheel and 30mm bosskit spacer.
  14. Wow! Attention to detail! Awesome build, looking forward to seeing your progress.
  15. So it's been a while since my last update. I fitted the exhaust Painted the wiper arms, window cowl and mirror door plastics with matt black paint Got some seats fitted What a massive improvement when going around corners. I sit really low in the car now too. Thanks for looking:)
