EP91crazy
    170
Everything posted by EP91crazy
  1. Is this between a td04 and ct9 hybrid?
  2. Cheers just waiting on 1 person to pm and will let u guys no
  3. How much you want for them ? Both of you guys ? Posted to po8
  4. After a working and good condition hybrid with no work needed or a standard ct9 that I can use to get converted so not to take mine off the road...
  5. Got a set of shocks and springs unknown drop but have pictures of height
  6. Replaced thermostat fan was working few days later started getting hot found fan wouldn't cut in. Diagnosed it was fan switch going into the thermostat housing so replaced that. Got car up to temp rose to the grey bar below H still no fan so turned it off waited a few mins re started and fan was on but for 10 seconds then went off? ?
  7. Right replaced the fan switch as found that wasn't working. Ran car up fan didn't cut in temp got to the thick grey bar below H on gauge so I turned her off... waited 10 seconds restarted and the fan was on for 10 seconds then went off ?? Dodgy thermostat maybe
  8. If they have a dimmer then they need to be connected to something that's switched on. I.e your lights so it dims with the lights... In the bulk head by the master cylinder there's a bung for the main loom you can remove it and it comes at the bottom of your acceleration pedal
  9. I've got springs and shocks lowered ones full set unknown brand though
  10. Working out bills later will pm i
  11. I checked the water level and it dropped from the cap to just above the cooling grids in the rad so a few cm il bleed it aagain and see but still need the fan too work
  12. Where abouts is the rad plug? No sensors going to rad? Air con removed if helps
  13. Where abouts is that relay??
  14. ^^^
  15. ^^^
  16. Fan doesn't seem to cut in . Temperature is steady till I boot it then it rises to 90 % pulled over to find a slight leak from a hose not clipped properly. Fixed that drove off. Booted it and it rose again and no fan... rads a half civic rad with small fan to suit. .. any ideas
  17. Get payed Friday. .. fingers crossed it's here
  18. Ah cool just only seems to be noisy on idle. When reving it goes ... if its common and not a issue then cool cheers
  19. Got a ticking sound coming from near the inlet... grtting louder since I bought it last year. Milage is 105,000 timing belt done at 74000
  20. Mm portsmouth lol guessing that's why you got pulled for them scrubbing? Lol and don't really want to flare the arches. May just leave them bud
  21. Hmm... not sure as offset could be too much...
  22. Offset ?
  23. Would these fit over glanza calipers?
  24. Mines the same driving round normal it'll sit 1/4 of the way until give it the beans then it sits at normal and the fan will kick in... but if I don't boot it, it stays low unless sat idling
