zf_165_gt4
    6
    Quebec,Canada
zf_165_gt4's Achievements
  1. mech5107 yes please share a sample thanks
  2. Hi, I'm the one making those tools and developing the app, refresh rate is effectively 1.3s, this is a limitation that all toyota obd1 ecu have. about logs, the format is meant for it being read in ms excel or open office, on top is the human readable data, down low is the raw data. it's mostly meant to be read as is for troubleshooting( I know this is not the best ;) ) or run custom vba macros on that data. It's also meant to be imported back into other's people android device for data replay or building back maps from a few engines logs. if there are some very popular standards for logs I will consider them just let me know. so to view logs, you can do a data replay directly in the android app, no ffwd pause or anything else yet. you can also export to .ctr files to open logs with the old russian Cartester8000 app in windows where you can do a replay too and play/pause the data.
  3. For now I have no interest in an IPhone port, I do not know much about programming for that OS and it could take a while to get something working.
  4. Hi guys I wrote TOYOBD1 and designed OBD1READ, JayJ freeze has been corrected in the devices sold after 11 september of this year. Older devices reprogramming can be arranged with me if needed. the After start enrichment mode is supposed to go off after X cycles have been counted. contrarily to Warm up enrichment it is supposed to be present at every engine start even if it is allready hot how to install OBD1READ http://jfbreton.blogspot.ca/2014/10/toyobd1-android-datalogger-how-to.html how to get the application working with it after http://jfbreton.blogspot.ca/2014/10/toyobd1-android-datalogger-connecting.html nice work by the way JayJ. here's the EP82 I owned for a year https://www.dropbox.com/s/w1tez890b8ij535/2014-08-17%2011.48.14.jpg?dl=0
  5. Hi, I wrote TOYOBD1, there is no use trying to get it to work on and emulator because of the Bluetooth capabilities it requires from you phone/tablet. even with the Android emulator within Eclipse it was useless to me, I use a real phone for testing. thanks
  6. Hi, I am the one that wrote TOYOBD1 and the OBD1READ devices if you have any more questions just post them here or PM if it is private. thanks
