JBishop
    20
    Warrington
1350 profile views
JBishop's Achievements
  1. It will spool faster by 300 to 500 rpm? Wow that’s impressive. I will have keep an eye for one
  2. What power do you think td04 on stock 5e 10psi make do you think pal
  3. Wondering if this 200mm xtd clutch will hold at that power
  4. So it works fine and drives nice? What will the 5efe make on a td04 at 10psi that’s what I’m going to be putting it up to and will it be safe at that?
  5. And did you use that flywheel pal? Just bought same xtd clutch but 200mm but wondering if it will hold now, what do you think? And do you know how much stock 5e can handle?
  6. Been speaking to you mate not sure I want one that’s been modified but what power did your xtd 6puc girding stage 3 handle? And was it 212mm or 200mm?
  7. Need 5e rods but how much for just pistons?
  8. Forged pistons Performance valve springs 3e flywheel/ 5e clutch conversion so I can use 4efte clutch decent clutch!
  9. Somehow my idle screw has come out of my throttle body, has anyone got one?
  10. Just thinking of centre to outer diameter of the clutch pal as the bigger clutch takes more to spin it. If you get me?
  11. Hi, my glanza is running a stock 5E bottom end and I’m wanting to stay with the 200mm clutch for quicker revs, is this possible and is there any clutch out there that will hold? And if any one has td04 on a stock 5E with glanza Head, what power have they had out of it ?
  12. Also after a decent clutch 200mm or 212mm
  13. Parts wanted for my 5e build asap! Wepr kit td04 with ex gated (doesn’t need to have turbo or wastegate) Pistons Rods Full engine gaskets Acl bearing Arp studs/bolts Uprated valve springs Decent clutch to handle 300+ Injectors
  14. .
  15. How much not really keen on wastegate position
