LewisSussex
    47
About LewisSussex
  • Birthday 04/18/1997
    Tonbridge
  • Build Thread
    103135
2022 profile views
LewisSussex's Achievements
  1. Hi guys, once again I'm having more problems with my glanza😡. Really starting to get fed up with it. Basically all of a sudden my fag lighter, radio, clocks and rear lights have stopped working and all the fuses are okay. I got a multi meter up to the back of my radio, I've got a good earth and a switched live but no constant live. Can anyone tell me where to look. Thanks
  2. I bought it off someone that had bought it brand new but not used it and I've got the actual instructions now cheers anyway
  3. Hi guys, I've just bought a brand new 2nd hand abs removal kit. It didn't come with any instructions or anything. I didn't wanna start removing pipes and stuff without knowing what are the right pipes to remove. Does anyone have a guide or can point me in the right direction with a few pictures. Thanks in advance
  4. Hi guys. once again, the minute I get my car fixed another problem decides to jump out. I took my alternator off to change the belt and sort out a small oil leak from the dipstick tube. I replaced it all fine started the car up and it was working all fine so I turned it off and went to lock it and my fob didn't lock it so I manually locked it. A few hours later I got my delivery for a turbo to manifold gasket. so I decided to take my turbo setup off to change the gasket. I changed that all fine. once I changed that I went to start my car and it wasn't cranking over. when I put my keys in the barrel it was beeping at me like it normally does and the light to say a door was open came on. so I then turn the ignition on and obsoletely nothing. I get no lights on the dash what so ever its like the car is still immobilized or something. when i press the buttons on my fob a little blue light signals that I'm pressing it so the batterys not dead on my fob and i tried connecting a jump pack to my battery and still exactly the same thing was happening. I'm soo confused why this is happening.# any help would be much appreciated really starting to get fed up with this now.
  5. Thank you guys really appreciate it
  6. Hi guys, Basically I just need a little bit of help regarding where the gearbox and engine earths should be. When I bought my glanza it had a earth going from the O/S engine mount to the strut top and I know for a fact that is in the wrong place but I don’t know where it should be. Where should the gearbox earth be bolted to as well as I know my one is also in the wrong place. I will be relocating the fuse box in the next few weeks so if anyone has any info on where they hid there earths I would really appreciate it Thanks in advance
  7. needing some help with some earth points for the engine/gearbox
  8. As it says in the titles guys, I'm in need of a bit of help. is anyone able to tell me the locations of the earth wires as I'm pretty sure mine are in the wrong place when I bought it. my cars got one going from the o/s engine mount to the strut top. any help will be much appresiated
  9. Cars all sorted now and driving amazing! Took it for a few test drives and already had some neighbours trying to stop me halfway down the road to complain about the noise. I wasn’t even giving it some lol. Anyway back to the car, within no time at all I had the gearbox out for painting as it was looking old and mankey as well as them horrible blue mounts as well so I painted the lot. Does anyone have any links for new bolts as it would just top it off? Decided to paint some more bits as well Got a delivery yesterday for a load of parts to get me through my MOT.
  10. Needing some help with a wire tuck, started a thread in the electronics section
  11. As it says in the title I need a bit of help with my wiring as its a mess. I want to wire tuck/tidy up my engine bay but firstly I need to start with the headlights as it looks a absolute mess. I've got a few pictures and need to know what's what and what I can get rid of. There is one picture that's nothing to do with electrics but what's the point in making a whole new thread for 1 picture. Also, I know what to do about moving the fuse box i.e tape up and number all the wires, move the fuse box to desired location and extend the wires. where are people running there wires through?. Perks of having a car the previous owner didn't look after right? lol Thanks to anyone who helps I really appreciate it O/S headlight wires/boxes? What is this connector and where is it meant to go? Where are these grounds meant to go? N/S wiring and HID ballast and what's that rubber thing lol What is this and can I get rid of this?
  12. Looking great mate!, What lip is that on the bumper
  13. Got all the lights to go off , no more EML, ABS and oil pressure. Just waiting for a connector to come through the post for the coolant temperature sensor. Also got the wiper arms pained as well as they wasn't looking too good. Looks Soo much better
  14. okay mate ill have alook when i finish work, will it go off with just the ignition on?
