Dave@TM-Developments.com
    292
  • MSN
    daveburwash@yahoo.co.uk
    Essex
6759 profile views
Dave@TM-Developments.com's Achievements
Member (4/8)
  1. Iddy, no he has not contacted me by phone or email. of which he has both. It was explained last week that I had problems with paypal and I would refund him as soon as that was sorted. Since then there have only been comments on facebook which I feel is the wrong place, just pick up the phone. The repair was carried out and the bolt was already loose. We managed to loosen it further and then re tighten it quite easily without it breaking. I would suspect it was then undone with an impact gun that probably caused it to sheer in the first place. His remaining £25 was refunded last night at 11pm by bank transfer. It seems some people would rather post comments on here or facebook than pick and the phone. Had he explained he could wait no longer on the phone I could have arranged a bank transfer there and then
  2. Bring it back Ash, I'm sure it can be done the same day
  3. Just found the text, 17th Aug I told you bring it back
  4. You were supposed to bring the car back weeks ago??
  5. We could have done the whole job on a different day for you
  6. Have you not a new arm?
  7. That would have been your best bet Ant
  8. We welded the captive nut on, had nothing to do with taking the bolt out
  9. Quite an easy fix, you have to cut away where the nut is, weld it on and then weld the cut out back on, done loads of these
  10. Bollcks, Exedy are far better, have run over 400bhp through one
  11. Empty your inbox Georgie
  12. One I could understand, but two would lead to me think there is another problem, maybe too much voltage? Any way the results of what they find should help
  13. I will ring them again tomorrow about this I have still not heard back from them and make sure you get a replacement. Mind you as this is the second one I would start looking at what is causing the problem
