Sobshotta
    39
    Barbados
1213 profile views
Sobshotta's Achievements
  1. Are they any good? Any good reviews or bad?
  2. Hi guys. I bought the speedvision camshaft some years before but lost the sheet chart he gave me. Does someone have the chart and can send me a copy please. Ive installed the cams but i noticed my compression is a bit low 130 on all cylinders is there anyway to rectify this? We tuned the car it feels very laggy down bottom on a gtx2867r gen 2 and it spools a little slow which shouldnt be Thanx
  3. The build can be read here: https://tdsautomag.com/
  4. Was building this set up for the last 2 years
  5. I recently built a forged 4efte on speedvision cams but no matter what I do it runs rich. I changed the injectors back to the stock ones checked the map sensor stock ecu and even my greddy ultimate and it still reads rich. Any idea on what's causing the problem?
  6. Running 15psI with a methkit and stage 2 exedy clutch
  7. I'm going to up the boost a bit only at 11psi investing in a meth kit and a stage 3 clutch it should feel heaps better after that
  8. Gt2871 comes in around say 4000rpm it's not bad at ton of top end power
  9. It was the distributor the car is working great nice mid and excellent top end
  10. Hey its pretty Strong up top but I've encountered problem, just got it tuned and was testing and the Intercoolerpiping blew off after we put it back on went testing it again and it wont rev past 4000 roughly when boost cuts in any ideas what it could be?
  11. It's a stock 4e Yes the engine should be forged soon Pump gas Water meth kit coming soon I was advised by a few people it would be a good set up for drags And your opinion is appreciated what turbo would you recommend?
  12. Ended up using the gt2871r it's a bit of a tight fit just have to get the down pipe finished and tuned
  13. Eventually and the power goal is around 300+
  14. Hey guys I'm back again I bought: Aftermarket manifold Fpr External waste gate A new fuel pump Greddy ultimate All that's left is the turbo choice which would you guys recommend for a stock internals street/drag set up. The gt28 or the gt25
