Thonfella259
Member-
28 -
N.I
Thonfella259's Achievements
š¤š¤š¤š¤ sweeet build
4 door itbs (haltech, all motor)
Thonfella259 replied to Thonfella259's topic in EP91 Progress Blogs
Started a YouTube channel there, gonna start documenting the car and maybe some tutorials and general fucking about, will still post on the forumš -
Lil update, cold start dialled in and a shitty custom cluster delete thingyš¤·āāļø IMG_0410.MOV -
Cheers @shorty and itās only going to get more awsomererererer𤣠-
Well I finally got the fucker started, more updates to comeš¤š¤ IMG_0223.MOV -
Another update on the carš¤ Itās been a while since the last update, just been busy with work but Iāve been chipping away at it. my main goal is to make it as light and as simple as possible, so Iāve completely stripped the insides, door skins will be cut out as well as plastic windows, all lights will be wired from scratch (yet to doš½). cool little centre piece Iāve made for the gauges and switches, made from the factory door card designš¤ As for the engine iāve gone for a haltech elite 550 with a basic universal wiring harness, k20 coil packs, 4efte dizzy for the crank and cam trigger and Iām still running standard injectors for now, still need to get a haltech tps but Iām using the built in map sensor to get it fired up. All wiring will be covered with heat resistance tape so itāll not be staying all exposed like thatš Few photos here for all to see𤣠-
Cheers Sam, will get a video up soon, proper little rocket now (for a 1.3)š -
Havenāt been on here in a whiiiile, few more things done to the car ā¢rebuilt head ā¢port and polish ā¢fidanza lightened flywheel ā¢and a lovely set of superlitesš -
Very interesting Sam, always thought 4efe and 4efte cams were the same, shoot me a message there and we can get something sortedš -
Cheers Sam, is it true that they have slightly more lift than the 4efe??? -
my itb setupš
View of the throttle bodies under the bonnetš«š 6DD95247-227B-4E9F-B626-D55F3C122D6B.MOV -
55mm is the outside diameter on the intake sideš, as for management Iām just using a det3 on piggyback mode with aem wideband, only real adjustments I had to make is try to make it idle and it was running slightly rich up top and lean down low in the revs which I have corrected but other than that shes sweetš
