Hi guys.
Time ago @Sam44 suggested me too use the Corolla inlet on the FTE engine as the airflow is better. Considering the technical differences such as the vacuum pipes, the water pipes, the sensors and the Air Control Valve, I would like to know if I can use the FDE throttle on the Corolla inlet and add what is missing on the intake swapping it from the FTE intake. My major concern is the air control valve that is usually sitting on the left side of the intake and must be swap with the Corolla air sensor that will be charade in another position on the right side of the intake.
@sam44 pic shows how you can put the air sensor in the four in one intake side to remove it from the left side where the air control valve can be positioned if I could use the FTE throttle then the rest of the water and air pipes would be OK
let me know what you think!
@Claymore
