Battery is the first thing to sort, without it we're pissing in the wind.
40ms is the maximum time that DTA can handle. I brought that down to 20ms last night by adjusting the start map, but the battery was the biggest factor last night, I'm sure of that.
Here's the fuel map, now don't shoot the messenger, this what was found on the base map. Which for what it's worth was for a 4efe which had a 4efte distributor fitted to it for the triggering.
You can see from the video it's using Row 1, Column 10 when cranking, so 11.26ms of injector before any compensations have been applied to it for water/air temps. The injectors are standard things from what I can tell, so 295cc?
I'm not even getting a splutter from it at the moment, but like I say, I'm trying to keep things simple and solve one thing at a time, the biggest issue right now is the lack of battery voltage when cranking.
