Guard1an
    22
About Guard1an
  • Birthday 09/10/1983
    Greece
2083 profile views
Guard1an's Achievements
  1. where did you get these projectors? any link available?
  2. http://www.toyotagtturbo.com/forums/showthread.php?28380-ABS-Diagnostic&p=350165&viewfull=1#post350165
  3. Better quality this time
  4. I sent you pm on TGTT.com mate before writing this post
  5. Hello, does any one have available brake proportioning valve and willing to post to Greece?
  6. Also interest in this! Tell us details.
  7. You can rotate the brackets the opposite way so problem solved
  8. I believe Greddy one requires no trimming, not sure if it fits UK N/A model.
  9. Bayside Blue is my favorite
  10. Your inbox is full mate
  11. No no no... you are missing something, the total width of the bush and the mounting position. Oem and powerflex bushes are both 60mm in width so if you want to turn the bush down to fit in the ring you must also grind the sides of the ring about 3mm to fit the bush correctly into the mounting position. To fit mine i took measurements from old bush, took the ring out, made two new rings and weld them in the axle and now is perfect. Here are some photos to show you:
  12. http://www.ukstarletclub.com/forums/index.php?showtopic=49151 />http://board.tercelonline.com/viewthread.php?tid=39844 Not a perfect fit to EP91 beam, they are designed for EP82 beam. Check the second link to see the differences between two beams.
  13. Nothing important, they want photos from installation but i didn't fitted mine yet. They also said that they are not listed this product for Glanza, only for GT but there is only one section on their website for both cars! />http://www.powerflex.co.uk/products/Starlet+Turbo+EP82+%26+EP91-2614/1.html If i have some time this weekend i will send them photos, along with better description of the problem.
