BoGlE
    314
Everything posted by BoGlE
  1. Its at R.A.F cosford buddy. If you want a good parking space on display you need to arrive at hlf 8 or at the latest 9..
  2. As said^ is any one going? Joe
  3. Update: ive sprayed brake cleaner everywhere with the engine running and there was no change in the revs at all. ive also orded a boost gauge . joe
  4. Here you go...
  5. Cheers.. will give that a go later on buddy
  6. well now uve sed that i think because i mite be running so little boost its doing the same as yours on 0.2.would it not be getting enough pressure to open the dumpvalve fully then?
  7. sorry..its a blitz dump valve.im unsure of the model. it has the hi lo boost disconected and i think its had the limiter off 1st and 2nd. ive checked my actuator whice is the standard one which is moving fine.ive checked for loose pipes and i cant seem to find one. im unsure of what actual boost im getting but ill be getting a gauge asap to find out.
  8. hi not long had my glanza but is it right for it to be dumping and chattering?if i let my foot of slowly it will chatter but if i do it quickly it will dump? i also have a boost problem do you have any suggestions on what to check and how etc? joe
  9. BoGlE
    Td12 Dyno Results
    hopefully start saving for the kit soon,looks awsome..but what does rev 2 larger/smaller ar mean?
  10. hi im going to be buying a glanza pretty soon but because there imports the indicators are on the other side yeh..but because of a disability i cant use this setup. so my question is can you transfer a normal set of starlet stalks to a glanza so that the indicators are on the left? will they just fit straight on? i cant see any reason why you wouldnt be able to fit them straight on but i need to be sure. cheers joe
