Content Count
2560 -
Store
Calendar
Hi I'm after a 5e to start my build cash waiting. Contact me on this, 07791117851 or chrisgreen1993@hotmail.co.uk Thanks
Been up round that direction a few times, but not recently. It is indeed Ryan, made a good bit of a difference
Thanks for the kind comments guys
OK so I though it was about time I created a thread as I have some big plans for over the next couple of months, while I have no License . I bought the car last September (2010) with 80K miles when I passed my test. The bought the car like this: The spec was: Rota Slip Streams 15inch Lowered 60mm Circuit sports lug nuts Remus Back Box Clear indicators Unknown induction kit. Just before Christmas the engine started to lose oil pressure on tick over, then the oil pressure switch went and ended up spinning the No3 crank shell. The car had to come off the road for 3 weeks while a f
what about the Bee R Rev limiter, would this not be similar?
Thats what happens when you cut your springs lol
Belfast/ Co Down Mainly Mondeo st220's Scoda Octavia Passat's
I moved the earth wire back to the manifold. I'm still having the same problem anyone else have any idea what this could be? Cheers
where can i get a remus backbox for my n\a starlet?
Chris Green replied to Billy SR's topic in Intake, Turbo & Exhaust
I got mine direct from remus, although this was about 2 years about and was fairly pricey as well -
I got a 10mm one that went on to the rocker cover. Auto Silicone Hose's mine was around £3-4, looks good aswel
would a standard glanza back box fit onto a n/a
Chris Green replied to drongo boi's topic in Intake, Turbo & Exhaust
The Glanza exhaust has 3 bolt holes and n/a only two, i got mine welded -
I try that that out, Cheers Buddy
ah, that could be the problem, by firewall do you mean the bulkhead?
I did that last weekend :/ when i was putting a rolla mani on just check it again there and it seems to be fine. It climbs quite slowly and just goes off the gauge.
Ok, so I just wired up and fitted paseo dials. Everything is working fine on them except the temperature gauge. When I turn the key to ignition the neddle just rises off the scale. Does anyone know if this is my wiring or is the gauge broke? Cheers Chris
There is a cheap set oh ht leads on ebay for a Paseo would these work on the 4e-fe? Cheers
OBX MANIFOLD FOR THE PASEO
You could just run a hairdryer off your battery
i had a problem like this on my sportif. Does the oil light flicker or come on only on idle?
Just wondering if there is an aftermarket for performance exhaust manifold that can be burchased for the 4e-fe? thanks
Difference between 5EFE & 5EFHE cams?
Chris Green replied to Chris Green's topic in N/A E-Series Engine Discussions
Thanks -
I'm wanting to put a different set of cams in, just wondering is there any difference between the 5efe and 5efhe cams? thanks chris
if your breaking the engine, i'd take your cams pm me!
I have a set of circuit sports lug nuts, they are a good job (y) http://www.circuit-sports.com/Pro_show.asp?proid=81
Help, Fitting a aftermarket rev counter to a sportif
Chris Green replied to Chris Green's topic in Electronics
Where do i find this black wire? is it the one coming from the distriputer? Thanks Chris
