wull
    48
About wull
  • Birthday 11/25/1985
  • Website URL
    http://
    killin,scotland
wull's Achievements
  1. the first series was on last year on fx.the 2nd series should be starting soon,i know its not channel 5 but most peeps have sky these days so fx is easily accessible.
  2. i was going through a rocky patch with the missus a few weeks ago,but we kind of sorted things out.we have a son together who is 5 now which kind of helps i suppose. but my previous relationship was a longish one,about the same as yours and sometimes these things are for the best.i'm sure you will feel better as time goes on and realise it was for the best. good luck fella
  3. i feel like i know so much now from being on here and tgtt but i still have a few things that have me stumped which i will query at some point but last night i thought nearly every td04 i have seen is running ext wastegate with screamer pipe etc and the ones you buy as a kit are like that so thats what made me think....so i had to ask that setup looks nice mate
  4. cheers man,i've seen a few and i couldn't see any ext wastegate so it got me thinking.
  5. does the td04 turbo run a internal wastegate or external one? and if it does run a internal one does the kits you buy have it welded closed or are they manufactured without as its part of a kit? cheers peeps
  6. brilliant
  7. might get that aswell
  8. wow,thats low....very low i like those arches,never seen them before,a bit different......really set it off
  9. do you get to drive it?if so you are one lucky bassa
  10. that explains it then
  11. looking at your car from the front how does it go...... from the turbo across to the right side then the pipes from the left of the fm goes back across then up the right side to the inlet manifold.is this correct? in the picture where you can see the bov,is this fitted to the pipe that goes from the fm to the inlet manifold?
  12. nice build mate out of curiosity what way is your fmic pipes routed,i thought it was strange to see the bov and the pipes heading across in front of the manifold........ probably some explanation for it but i can't understand why its like that lol
  13. i was thinking..."i've only just finished reading the build thread ffs"...lol
  14. i agree,i would of expected this to cause the turbo to over boost.
  15. what power do you think its running just now at 0.8?
