5e colin Posted March 16, 2016 Posted March 16, 2016 hey lads im trying to connect my wideband to the laptop to adjust some settings i had to buy a ebay db9 to usb converter and the laptop cant find the driver for it keep getting the message in LM programmer no serial connection do i have to get this instead its the same thing only its innovate 1 http://www.amazon.com/Innovate-Motorsports-3733-Serial-Adapter/dp/B000CO9MFS Quote
Charlie28 Posted March 16, 2016 Posted March 16, 2016 I'll keep my eye on this because i also need to plug my Innovate gauge in to set Oil pressure warning limit Quote
5e colin Posted March 16, 2016 Author Posted March 16, 2016 the inove converter is like 50e the 1 i bought of the bay was like 5e no driver cd with it Quote
Bug679 Posted March 16, 2016 Posted March 16, 2016 Did you download the driver for the adapter ? What's your laptop running Quote
5e colin Posted March 16, 2016 Author Posted March 16, 2016 this is the exact 1 i bought http://www.ebay.co.uk/itm/120930946681?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT and im toshiba satelite c55-1w7 windows 8.1 64 bits Quote
Bug679 Posted March 16, 2016 Posted March 16, 2016 (edited) There's a list of drivers on this page think yours should be the second one for Windows 10/8/7 64 bit have a look and see if it helps. It doesn't give much info on the item description on eBay. If that fails ask the seller he should be able to help you. https://serialio.com/drivers-and-set-up-usb-rs-232-adapter-in-windows Edited March 16, 2016 by Bug679 Quote
5e colin Posted March 16, 2016 Author Posted March 16, 2016 tryed that there and installed it and it gives code 43 ? what ever that means Quote
Bug679 Posted March 16, 2016 Posted March 16, 2016 http://stackoverflow.com/questions/24207131/code-43-windows-has-stopped-the-deviceLooks like Windows stopped the program from loading if ya try to restart your laptop or if that doesn't work try reinstall and restart then. It should work just could be a bitch at times. Quote
Johnboy GT Posted March 16, 2016 Posted March 16, 2016 I think you also get the option to select a serial port, maybe worth checking that to make sure it's reading it.John Quote
hopalong_neil Posted March 16, 2016 Posted March 16, 2016 Hello mateGo here and download the drivers, link underneath the descriptionhttp://www.sordan.ie/product/137/usb-to-db9-serial-adapter--cd-cable-rs232-9-pin-gps/I was trying to install a similar lead in my laptop last weekend and only worked when i found the correct manufacturer driver. Quote
5e colin Posted March 17, 2016 Author Posted March 17, 2016 downloaded that driver there trying to fucking unzip it bwaaa fucking laptops they do my head in not easy Quote
5e colin Posted March 17, 2016 Author Posted March 17, 2016 well soooooo the extract worked BUT where de feck did the file go now ???? is it automatically installed now ?? Quote
5e colin Posted March 17, 2016 Author Posted March 17, 2016 feck it it keeps on saying driver failure when i try to install brrrrwwwaaaa fecking crap Quote
hopalong_neil Posted March 17, 2016 Posted March 17, 2016 When i did mine i plugged the cable in and let windows do its thing trying to find a driver. Once this had failed i went into device manager, right clicked on the cable that should have a yellow warning on, picked properties, then the drivers tab and update driver. Next pick search yourself and then browse to point it to the folder with the driver in. It should then install.This stuff can be soooo frustrating, it took me so long to sort on my laptop it was too late for me to do what i wanted. Quote
5e colin Posted March 17, 2016 Author Posted March 17, 2016 keep on getting """" device descriptor request failed !!! Quote
Ollieh17 Posted March 17, 2016 Posted March 17, 2016 Have you tried turning it on and off again Quote
5e colin Posted March 17, 2016 Author Posted March 17, 2016 yes many time is it becouse the usb to db9 has no ftdi chipset ??? maybie i have to buy 1 with the chip ???? Quote
aleximport25 Posted March 18, 2016 Posted March 18, 2016 Have you tried turning it on and off againYou sound like an IT call centre 😂 Always their first question haha Quote
5e colin Posted March 18, 2016 Author Posted March 18, 2016 still no joy think i will have to buy the inovate cable Quote
Bug679 Posted March 18, 2016 Posted March 18, 2016 Did you not find where the driver installed on your pc ? you might have to run as administrator before it will work ? Quote
5e colin Posted March 18, 2016 Author Posted March 18, 2016 did al that and my freind whos more pc minded cant get it to work either i deleted everything and he re downloaded the driver and logwaorks etc and keeps happening its probly the cable as it has no ftdi chipset ?? this 1 has http://www.ebay.co.uk/itm/USB-to-Serial-Adapter-High-Quality-FTDI-CHIPSET-RS232-BT232-WIN-7-8-10-DB9-/151406431857?hash=item234086ce71:g:VUUAAOSwLVZV4Bf4 Quote
Bug679 Posted March 18, 2016 Posted March 18, 2016 Looks better quality anyway do you know what software your gauge needs to read what wideband is it before ya buy anymore cables ? Quote
.ep82. Posted March 18, 2016 Posted March 18, 2016 If you had of lived closer id have lent you mine lol Quote
5e colin Posted March 18, 2016 Author Posted March 18, 2016 Looks better quality anyway do you know what software your gauge needs to read what wideband is it before ya buy anymore cables ? logworks 3 is wat innovate says so have it downloaded and it automatically installed lm programmer to adjust the settings in the mtx gauges ep82 are you up and running with your gauges ??? what exactly is involved in the """ setup"" to connect to the gauges ?? computer recognises the converter cable then plug in the cable to the gauge and start up the llm/logworks to do your think ?? Quote
aleximport25 Posted March 19, 2016 Posted March 19, 2016 Wouldn't someone in here lend you the cable for a small fee ? Quote
