innovate gauges isseu
hey lads im trying to connect my wideband to the laptop to adjust some settings
i had to buy a ebay db9 to usb converter and the laptop cant find the driver for it keep getting the message in LM programmer no serial connection
do i have to get this instead its the same thing only its innovate 1
http://www.amazon.com/Innovate-Motorsports-3733-Serial-Adapter/dp/B000CO9MFS
There's a list of drivers on this page think yours should be the second one for Windows 10/8/7 64 bit have a look and see if it helps. It doesn't give much info on the item description on eBay. If that fails ask the seller he should be able to help you.
https://serialio.com/drivers-and-set-up-usb-rs-232-adapter-in-windows
Edited by Bug679
When i did mine i plugged the cable in and let windows do its thing trying to find a driver.
Once this had failed i went into device manager, right clicked on the cable that should have a yellow warning on,
picked properties, then the drivers tab and update driver.
Next pick search yourself and then browse to point it to the folder with the driver in.
It should then install.
This stuff can be soooo frustrating, it took me so long to sort on my laptop it was too late for me to do what i wanted.
did al that and my freind whos more pc minded cant get it to work either i deleted everything and he re downloaded the driver and logwaorks etc and keeps happening
its probly the cable as it has no ftdi chipset ??
this 1 has
http://www.ebay.co.uk/itm/USB-to-Serial-Adapter-High-Quality-FTDI-CHIPSET-RS232-BT232-WIN-7-8-10-DB9-/151406431857?hash=item234086ce71:g:VUUAAOSwLVZV4Bf4
Looks better quality anyway do you know what software your gauge needs to read what wideband is it before ya buy anymore cables ?
logworks 3 is wat innovate says so have it downloaded and it automatically installed lm programmer to adjust the settings in the mtx gauges
ep82 are you up and running with your gauges ??? what exactly is involved in the """ setup"" to connect to the gauges ??
computer recognises the converter cable then plug in the cable to the gauge and start up the llm/logworks to do your think ??
