Duduglanza Posted April 10, 2016 Posted April 10, 2016 I know it something with the vss but what can i check? Whats the normal fault that throws this code? Quote
akyakapotter Posted April 10, 2016 Posted April 10, 2016 Never gotten to the bottom of it on mine just ignore it now lol Quote
5e colin Posted April 10, 2016 Posted April 10, 2016 try swapping out to another ecu as it might be damaged the ecu get its signal from the clocks so it might be something broke on the back of the rpm unit im not 100% on the next but might be worth checking dizzy to as it might work in conjunction to the rpm ignition table ??? Quote
Duduglanza Posted April 12, 2016 Author Posted April 12, 2016 Ive got an ultmate installed amd when i log .. the rpm signal is ok. Quote
