This is what has happened after a week of use head was rebuild skimmed and checked same with the block bolted down with arp head bolts to the right touqe settings arp provided me with every thing was good when driving couple days and all of a sudden i lost compression on cylinder 2 and 3 cracked the engine open to find a piece of the gasket missing between cylinder 2 and 3 any suggesgtions why this might of happend faulty gasket??
post-12458-0-60843300-1460300203_thumb.j
  • Replies 62
  • Created
  • Last Reply
Top Posters In This Topic
Block and head was checked and rechecked it was completely flat! Going to get It checked agin now the head is off do not have a clue what could of done this was on low boost was running sweet until it blew
There you go.. Mine tested as flat with a straight edge, but once it was on the machine for a proper check it needed skimming.
Looks exactly identical to mine maybe could be like you said might be slightly warped block was flat before fitted so very confused lol heard people have had issues with these in the past something to do with a faulty batch
The multi layer ones need absolutely fat surfaces to seal, you'll likely get away with fitting an OE one.
You'll need to rebuild the bottom end if you have to any work done on the block.
I opted for a rebuild, and now can't decided whether or not to fit an Athena or OE when I put it back together.
use a straight edge ruler or something true and flat and get the feeler gauges on it, pretty sure there is a manual on google search and you find all info and what to do, good luck
contact athena aswell so they know whats going on and may help you out some how ???
Sounds like a good idea might do that I know they did have an faulty batch a while ago was a sealing issue...
I'm pretty sure it will seal as the oem gasket is a lot softer it's not major warped the msl steel gasket didn't old long as the blocked didn't get decked before installing it
If you've got the head gasket might as well give it a go?! I would,and probably should have.
That's what im going to do mate its not majorly warped only slightly got an oem one here ready to go on
