NICKYG2X3 Posted April 21, 2016 Posted April 21, 2016 Hi i have recently fitted a Wepr Ramhorn Manifold - - Decat Fitted a new Ct9 hybrid turbo - Rotated - to fit All is fitted - - Now the only thing that doesnt seem correct is the short route intercooler pipe I've got. It does not line up -in fact its way off - Theres not much room - The bend at the top would now seem a pretty sharp bend - WHAT ARE MY OPTIONS? - plz (customs pipe? flexibile rubbers?does it matter if the pipe is now very very short) Sorry no pics Quote
NICKYG2X3 Posted April 21, 2016 Author Posted April 21, 2016 Some pictures would definitely help here i no right. errgh sorry. basically - the ramhorn manifold is fitted the turbo also fitted. so the short route intercooler pipe the normal id workz one from turbo now does not fit can i modify this short route pipe? cut it smaller etc or is that an issue? not sure why it just wont fit. Quote
daniel_g Posted April 21, 2016 Posted April 21, 2016 How rotated is your turbo?Would the short route IC pipe fit if you rotated the turbo a bit?Internal wastegate or external? Quote
TimD Posted April 21, 2016 Posted April 21, 2016 Take some photos otherwise you're going to struggle to get any meaningful help!!! Some people can't help themselves. Quote
NICKYG2X3 Posted April 21, 2016 Author Posted April 21, 2016 ye garage closed. wil do tomorrow - i was only seeing if worse comes worse it was ok to cut and fabricate my own short route pipe or not - tidyy spaaaa Quote
TimD Posted April 21, 2016 Posted April 21, 2016 Sure, go for it. If it doesn't fit now, you're going to have to sort something. Quote
NICKYG2X3 Posted April 21, 2016 Author Posted April 21, 2016 Sure, go for it. If it doesn't fit now, you're going to have to sort something. tidy spaaa (wales) Quote
