Front mount or top mount
Should be obvious really mate. A front mount will cool far better than a top mount. As the top mount sits ontop of a roasting engine. Only downside to a front mount is slightly more lag. But the upsides far outweigh the downsides mate. You will get much cooler inlet temps. Also looks much better aswell with a front mount
  On 4/23/2016 at 4:24 PM, carlosd87 said:
Which has a better cooling a tmic or a fmic, I have a standard TM at the moment was thinking of upgrading? Any help? Cheers
Front mount is much better all round.
Front mount is far better, was 1st thing I fitted to mine. Lag isn't very noticeable on the ct9 anyway!
And you won't lose power, if anything you'll gain some from colder/more dense air. Mine pulled so much stronger with the fmic.
I've seen kits on eBay for less than £200
Edited by adzy
