Right i'm quite over my head now with all this shit, tried reading up as much as I can but need some actual help now.
I'm gonna be a running a GT2860RS on a topmount setup, I have no water/oil lines with it.
I believe the thread size is AN4 for oil and water lines, is this correct?
I have also read about the GT28 requiring a oil restrictor?
What can I use for oil return?
I just need to know what to order, I'm so deep and lost at the mo :fool:
Any help much much appreciated.
Im having similar issues atm dude.
I just bought some hydraulic hose from ebay for the oil return. Its 1m and 3/4" ID, just cut to size. Its got 2 layers of braiding inside so takes some cutting lol!
Screenshot_2016-04-27-10-09-50_zpsft8lii
Seems very cheap but its very good quality.
For the oil feed my original one was from Zisco. Im having to get one custom made so trying a few different places, local hose places etc.
Also WEPR can defo sort you out :)
Ooo that hose looks perfect saying that, reckon it can take the hot oil for prolonged periods then?
Didn't think about WEPR, will drop sacha a PM.
Cheers!
Hel website allows you to build you own oil feed - result £30
The oil return you just buy the two bolt push on fitting on eBay
And two water lines push on banjos again to suit a gt28 off eBay
Phil
Phil
Oh that HEL custom site is amazing, will build my own when I'm home so I know what length.
For oil return on the turbo, I already have the adaptor plate thingy on it, so I just need pipe to go on the turbo and then onto the sump, I believe anyway...lol
God they are expensive, £15 each if you order from a UK supplier :o ?!
Cheers!
Its rated too 100*C so should be fine.
The last one i had that Zisco supplied cracked and split and caused a fire so i'll be checking this all the time.
Phil
Wish i knew that i've had very little luck getting a feed made.
Sweet, will order that pipe later.
Just spoke to WEPR, they can supply me a complete kit, but it is pretty pricey lol.
I've got a billet an-12 return you can have for not a lot if you want it. That'll fit a gt28.
Use An-6 water lines - torques is a good place to buy fittings.
An-4 oil feed. depending on your engines oil pressure and what bearing setup your 28 has you may need a oil restrictor like you mentioned.
Edited by RobSR
