Gainzy Posted May 5, 2016 Share Posted May 5, 2016 Going to be running 16x7 work wheels on 20mm spacers. Is the glanza 98 spec hub 54 or 55mm my wheel centre bore is 73.3 so I need 56.1>73.3 need to buy the right rings can anyone help? Just bought these Quote Link to post Share on other sites
Gainzy Posted May 5, 2016 Author Share Posted May 5, 2016 I need to measure the centre bore of the works..xd9's I think Quote Link to post Share on other sites
dan106 Posted May 5, 2016 Share Posted May 5, 2016 What's the centre bore on the spacers? Sent from my iPhone using Tapatalk Quote Link to post Share on other sites
adzy Posted May 5, 2016 Share Posted May 5, 2016 Is it a spigot to go between hub and spacer you need?Glanza Hub is 54.1 Quote Link to post Share on other sites
Broony Posted May 5, 2016 Share Posted May 5, 2016 I've already explained all this to you ?? Peter North drowning you? Quote Link to post Share on other sites
Gainzy Posted May 5, 2016 Author Share Posted May 5, 2016 I've already explained all this to you ?? Peter North drowning you?I know bit I still don't know what to buy doh! Quote Link to post Share on other sites
5e colin Posted May 5, 2016 Share Posted May 5, 2016 you need 2 sets 54.6 to what ever size is the spacer ( inbetween spacer and hub ) then the spacer size to your wheel size Quote Link to post Share on other sites
Gainzy Posted May 7, 2016 Author Share Posted May 7, 2016 What's the centre bore on the spacers?Sent from my iPhone using Tapatalk56.1mm Quote Link to post Share on other sites
Gainzy Posted May 7, 2016 Author Share Posted May 7, 2016 Is it a spigot to go between hub and spacer you need?Glanza Hub is 54.1Is that 96-99 all the same Quote Link to post Share on other sites
NewbieLewby Posted May 13, 2016 Share Posted May 13, 2016 (edited) Is that 96-99 all the sameYes. All 54.1 Edited May 13, 2016 by NewbieLewby Quote Link to post Share on other sites
