will standard injections map to 1.2 bar or 1 bar if not what will they map to and if i need bigger injectors what size will i need for 1 bar and 1.2 bar
you'll probably be close to the limit at 1.2bar on that turbo.
but your mapper will be able to tell you how close you are as he pushes the boost up.
Phil
