Having problems with my new glanza, i think it has a short shifter in it but its really stiff moving it left to right no issues going into gear. Is this just needing greased or any ideas?
maybe gym session ??? ha ha
na just check if the slave cylinder is working propperly after that check the cube on the box then cables you could grease them where they enter the sleeves inside and outside
Check the rubber bushes in the gear cables arent siezed to the selector tower.
On top of the gearbox
Edited by daniel_g
That happened mine when I put the solid shifter on the front. Think it just tightened the whole system up great job 👍🏻
I had this on mine recently the solid shifter bush had rusted on to the post in the selecter on the box stopping it pivoting and selecting gear. I actually bent the shifter cable trying to get it in to gear. Lol
I'm Still using the original TC tuning brass shifter bushes that came with my quick shift they've been on done years tbf.
Edited by rob_bower
