rippon91 Posted June 27, 2016 Posted June 27, 2016 As above there is a considerable amount of vapid that has started coming from the breather on the right hand side of my rocker cover, there is no Pcv valve as it goes into a catch can, what could be the cause of this? Quote
H_D Posted June 27, 2016 Posted June 27, 2016 vapour will be more visible in brighter light i.e sunlight... the whole point of the bigger breathers is to help crankcase vapours/gasses escape more efficiently.I highly doubt its your piston rings unless if it actually spitting out oil from the breathers. Quote
Ollieh17 Posted June 27, 2016 Posted June 27, 2016 Doesnt have to mean piston rings are complety gone..... Worn piston rings, more blow by, more vapour Quote
rippon91 Posted June 27, 2016 Author Posted June 27, 2016 Cheers guys I'll get a compression test done but is it likely to damage it more by using it? Quote
rippon91 Posted June 27, 2016 Author Posted June 27, 2016 Also I've read that it could be from bad grade fuel I.e supermarket fuel that I've just filled it up with, anyone believe this is possible? Quote
